210 wake taking on water... help
Messages
24
Likes
1
Location
lake st clair michigan
Water Crafts
2012 seadoo 210 wake
2014 scarab 195 impulse - sold
2012 seadoo rxpx - sold
#1
So I noticed I'm taking on water where the shifter cable comes through the hull I pulled it out of the water armed the plastic nut/ rubber thing broke on the outside and it appears the epoxy on the inside is also allowing water through.
Anyone run into this and have tips on where to start? Is that crappy nut/rubber grommet thing the main culprit or the epoxy on the inside of the hull?
JPass
Messages
1,033
Likes
100
Location
Orlando, FL
Water Crafts
2012 Challenger 210 SE
#2
I've read that these are prone to failing. You should replace the lock nut assembly. I believe the original is plastic, but they make aluminum ones. I picked one, but have yet to install it.
Users who viewed this discussion (Total:14)
Adsense
Usergroup
