Well gazzaskirepair was completely correct on how to replace it. I did not use any WD40 when removing the unit, but did add some silicon spray when installing the new one. After unhinged, when removing the old unit, the top main cover did come unsnapped in a couple of spots. This extra room did help in getting the old unit out and new one in the right location. I actually connected those points before doing the final push on the new unit to snap in it's hinge. When you're doing the removal and installation make sure the glove box lid is in the completely open position. I will add that to get the new unit back in I had to push harder than I was really comfortable with, but it worked. Last thing to note was I found it odd that I had to use a 7/32 socket to move the glove box latch to the new cover. I was expecting metric...
Lastly, I will note that this experience puts a negative note on my local dealership. I was told when the recall was performed that it was too labor intensive and I would have to setup another appointment for that. Even though I had told them of the need when I made the appointment for the recall. Honestly, someone who knows what they are doing could do this replacement in 10-15 minutes...
