Imagine a wheel bearing going bad in your car only that the wheel is spinning at 100 rpm when you hear it. Well that sound sped up to 3000 rpm sound alike a humming. Pull the pump and check the bearing. You will likely find that being the issue. I've found they make this noise for a little bit before doing damage. It's usually a sign of bad seals or corroded pimp shaft and water getting into the pump
