Thank you for responding, I am getting water in the hull not the engine.and the grommet on steering cable where it comes out of rear of hull .so when cable slides in and out looks like water can get into hull
OK, that makes more sense now...and I think I'm mistaken about water in the engine being used for cooling. If I am not mistaken, the SPARKS are sealed cooling systems with anti-freeze so water is not used for cooling purposes. SO, if you HAD water in the engine then you'd have a big problem on your hands.
Are you sure water is getting in past the steering cable?
Here's MY story of water in the hull of my 2017 Spark: I crashed my Spark, broke the hull front badly (basketball ball sized hole), it sank ass down but stayed afloat, nose up. I swam it home (1/4 mile) like that to my dock and hoisted it into the boathouse with a chain fall. Fast forward....new hull, swapped everything into the new hull.....put it back on the water. Next morning, she's almost underwater again, caught her just in time and pulled her out, full of water in the hull so I left it there, did NOT open the drain plug as I wanted to see where the water will come OUT. Found it. After watching it carefully, I discovered that the plastic/vinyl tube for the bailer/drain system inside the hull that passes through the hull to the outside was leaking. This is a bad design of the SPARK hull....Seadoo relies on the vinyl tube passing through the hull to be a pressure fit (the hole in the hull is slightly smaller than the vinyl tube so when you pull/push the vinyl tube through the hull, it is supposed to make a seal)....well, if that tube shrinks/dries out (from age, cold water)....water can sneek past the tube into the hull. The tube is at the rear bottom of the hull underwater so you'd never know it was happening until she starts sinking.
I ended up taking the top deck off again and goobered (with silicone) the hell out of the vinyl tube inside the hull until I had a seal....waited a few hours for the silicone to set, goobered up the vinyl hose on the outside (hard to do with the jet pump in the way but still do-able) as well. Put her back in the water and she has been good as new since...two seasons now and still going strong.
