rsviper94
I am having some issues with my 2013 RXP X 260 and need some help. I had pulled the battery out of the ski for the winter and then found out that the battery was no good so I purchased a new one, After installing the new battery I am having some issues.
1) When I connected the battery I keep getting a single beep and it keeps searching for a key and will not shut down by itself.
2) If I connect the key nothing happens unless I unplug/replug the 30A relay in the fuse box that is connected to the battery. After that I am able to start the ski. If I shut the ski off it will not restart unless I unplug/replug the relay.
3) I thought that it might be the relay so I put the relay into my other ski and it works fine. I also took the other relay and put it in my 260 and it acted the same as the original relay.
4) I am noticing that the relay seems to be getting very warm compare to the other ski.
5) I checked the fuses in the main box by the battery and they are all good. The battery is also fully charged.
6) The gauges will not shut off unless I unplug the relay.
The local dealer is 3 weeks out on service so I need to figure this issue out.
Any help will be greatly appreciated.
