Hey Guys,
sorry its my first post, but i promise i'll hang around and help out where I can
Im having an issue with my 2012 seadoo GTS 130.
When I rev it on the trailer, twice in succession it hesitates really badly .... when I rev up to just over 5k it misfires (whats the limit on these?)
I took it out on the river a few weeks back and all was going good. Cruising around 1/2 throttle and then came to a stop for no more than a few seconds. When I tried to take off it was very hesitant with a prominent 'vibration' and lack of power. As it was in the river I thought i had sucked something up.
I got towed back in .... around 20minutes and when I got to the boat ramp I started back up to nurse it in and load onto the trailer.
When I got home (no more than 2 hours later) I looked under the seat and had alot of salt water over the engine (around number 1&2). It may have been from previous trip a few weeks before as it had started to effect the paint (PIC below) ..... (I didn't clean the engine after the previous trip as I had no Lanox - bad, i know).
I cleaned the engine. Contact sprayed coil pins/connectors, changed the plugs- seemed good on the hose, thought it revved well (but now am doubting myself) ..... took to the dam.
Same thing.
Came back and changed the coils x3, offical seadoo parts.
Checked the stator. no pins to ground. all pins 0.6/0.7ohms pin to pin.
drained 1l of fuel from the fuel manifold, no water present.
no fault codes.
compression is around 165psi (number 1 may take an extra few revolutions to get up -they all drop back to 150/160ish and back up/down next revolution etc- but i think that could be the gauge/one way valve in the guage)
any advice?
Same thing.
no fault codes.
any advice?
