Massseadoo
So I recently bought a 2011 seadoo gti155 limited and i thought I got a good deal because it’s only got 53 hours on it so I went home and did and oil change and cleaned it up and I added a little too much oil and didn’t really compensate for the expansion. I just wasn’t really thinking and I really wanted to get out on the water. So I went out and it was good for an hour and a half and then started burning oil really badly. Right when it happened I knew i put too much oil in it and i didn’t want to make any more damage so I had my buddy to me home so I got back to the shop and there is no oil in the air box no oil in the pcv the only oil is in cylinder 1. I checked compression and compression is all equal at 150psi and changed the plugs and set the oil in the middle of the check mark for the dipstick and ran it to maybe try getting the oil out of the system but I ran it for a while and there is still oil burning... I look at the dipstick and it seems to be down a little so I’m not sure if I’m burning it off or if I’m just burning more oil from the motor. I want to do a cylinder leak down test but I’m not sure how to get it to top dead center to be able to do so. It just sucks because I just paid a bunch of money for it the other day and didn’t even make it 2 hours and now I just hope it’s not toast I really don’t want to rebuild it. My only thought is maybe it’s going through the valve seals or it blew by or is blowing by the oil ring in cylinder one. Thanks a lot and any input will help
