ProTurbo
Hello, Im looking for a Schematic Diagram for 2010 Speedster 150 I have downloaded and bought at least 3 Service Manual and they
don't have the right Diagram (either its not there or they attached the wrong one with the wrong ECM )attached to the service manual, Looking for the schematic with the Siemens VDO MSE 3.7r ECM (look PiX bellow) not he BOSCH me 17.8.5.
All started with some coils not firing up, replace new ECM still same problem, check all grounds, fuses, replace cps and tested, still no sparks.
I do get two beeps when the DESS is in, no faults showing( accept Sensor Sensor and goes away) and not fault showing with BUD system also, I can activate Coils (one is louder then the two though) and Activate Injectors not problem. I have a new Battery but it still cranking a little slow or hard to turn motor at first.
Running out of Options.
If you guys have any suggestions, feel free to comment and if you happen to have that diagram, i would really like to buy it off you.
Thank you v
Thank you v
