seamonsters
I hope you experienced guys can help. After changing oil, filter, coolant, plugs, and charging 1-year old battery, it just clicks. Starter not turning. Beeps OK. Gauges readout OK. It says MAINT and compass direction back and forth. Main relay buzzes.
It started fine just before and during oil change process. It decided to act up when I got everything back together. The only oddball thing I did was flush out the interior engine compartment with a hose. That's why I checked the fuses. Fuse box seals held. South texas so not a winter issue.
Checked battery, checked battery connections, checked fuses. Same results with trainer key. Dealer 100 miles away, but they have been relaible in the past. Should I start replacing parts, relay, battery, others?
Thanks in advance for troubleshooting ideas.
