Carboncow
OK, a bit scared on this one but after checking engine I saw I was not dumping oil into any visible area. Dipstick is wet too. Got the boat back to port via slow limp mode as I was afraid to shut off engine and restart. Back at port engine restarted, code cleared and took her for a spin.
First time I saw the code we had been running the bay for 45 minutes.
After the reset I rand it for another 20+...ran perfect. Slowed to idle a couple of times and on the 3rd run I threw the code, loud beep and limp home again.
So fairly inconsistent. Going to change oil tomorrow at dock just to get fresh in there and have a look at it's condition.
1. Would it be fair to assume a sensor is at work here? My experience is they tend to fail or not and stay that way but maybe the pressure range is just off?
2. Are there two sensor or one...see posts on 4 techs claiming both?
3. Can someone give me a big hint on the location around the oil filler?
or...
I know it's a cheap part and the do fail but as many of us know we shouldn't just throw parts at things...or should we on this one?
Or should I preform some type of actual oil pressure test under way and if so anyone got a good write up? This seems it could be a pain todo w/o some help.
Any advice on this project would be helpful.
or...
