you can pull the bearings out by using a length of threaded bar and a socket or washers that match the bearing diameter. There just a needle bearing and once pulled the cage will probably get damaged. So best to have new ones ready. You can pull them in with the same length of threaded bar. If you have a press, better still. You will need Seadoo synthetic jet pump oil to refill the pump.
