JoanEnric
Hi all!
I would like to ask you for some help.
The max speed of my 2006 GTX 155 is 44 mph at 7200 rpm.
Facts:
- I use the correct key, not the learning key
- wear ring is new
- impeller is new
- sparks are also new
- oil and oil filter (everything was changed in dealer this summer, all BRP original)
- oil level is a little above the max in cold (I know that level has to be between min and max, I need to remove oil)
- OPAS system seems to work well (or this is what I think)
- reverse gate is in place
So, with all this, what can cause that speed of 44? Apart from the impeller and the wear ring, and the fact that the oil level is a bit to high, what other parts are involved in speed? What other things should I look for?
Any suggestion, help, comment or idea would be very appreciated!
Thanks for your time and support!
Regards
Facts:
- wear ring is new
- impeller is new
Regards
