2005 Seadoo Sportster Vtec Problem
kosmo
Good day;
I am new to this forum and need some help. My boat has been trouble free until today. When I accelerate from idle or cruising speed, the boat is hesitating, jerking. It kind of acts like its a fuel problem. I checked the boats jet for a clog, none seen. Oil level is fine. I just added gas and this is the first time I have had it out this season. Do you think the little bit of old gas is reacting with the new gas? can I add stabilizer to the gas? Any other suggestions ? Thanks !
Welcome to the seadoo forum kosmo. I would change the plugs and see what happens the correct ones are DCPR8E gapped to .024 in. What did you do to winterize it at the end of the last season?
Karl
Try the fresh plugs in all the cylinders. That should cure any problems. Chances are that they are just fouled. If you still having problems give us a shout.
Karl
