Cpt Momo
Hello 4TEC riders
New to the 4TEC and I saw GTX SC with a smoking price tag that I can't miss. I'm 2 stroke rider so the 4TEC is whole new breed to me and would appreciate the tips.
Let me tell you, the first 4TEC I ever look into and it crazy how much compartments it has ... specially the cooler in the front! Compartments every where!
Obvious problems was "sensor" code and (according to owner) pump seal
It fires right up and the owner didn't mind taking it for a test drive tomorrow morning.
He did say the Supercharge won't work if the seal need replacing. It's a salt water ski and I don't mind since I'll be riding it in salt water
Things to point out:
The engine bay has white spots in it so I'm assuming some water was getting in there?? is that from the pump seal? Though he says it doesn't take water and is willing to take it for a test drive. He just said I never wash it the engine bay.
The pump housing came with two versions. Can someone explain the difference?
Update crank shaft?
About The ceramic washers on those pre 2008 4TEC . I couldn't find it in rhe diagram. Can someone explain it for me and what needs to be done?
how can I find put about the sensor codes? Which one to replace?
Anything I should look into?
Update crank shaft?
