2005 3D RFI no spark on 1 cylinder testing with CanDoo Pro ECM???
Karlosthejackal
trying to track down a fault on my 3D RFI. only runs on 1 cylinder constantly. Connected candoo pro and when individually activating coils with plugs removed and earthed can only get 1 to spark. Tested resistance in wiring between coil and ECM and both test perfect (0 ohms), but only 1 will fire a spark. The 12 volt feed to the coils is common so my theory is a faulty ECM?
Any advice or other theories would be gladly appreciated as the ECM is not cheap!!!!!
Since it appears there's two threads on the same subject, I'm closing this one.
Lou
