Hello again, I'm a bit confuse... Regarding the exhaust flush I understand that the engine must be running before pumping antifreeze in the inlet near the exhaust.
But when I'm looking in the shop manual for the sportster LE DI, it does not say that the engine must be running for the "antifreeze colant method on the engine head". This is what it says;
1- Install a hose pincher to engine drain hose near the PTO flywheel guard.
2- Disconnect the water supply hose at cylinder head.
3- Temporarily install a short piece of hose to engine water outlet at cylinder head.
4- Insert a funnel into hose and pour antifreeze mixed.
5- Remove temporary hose and reconnect engine water return hose.
6- Remove hose pinchers.
And :
Most of the antifreeze will drain out when removing hose pincher(s). Use a container to recover it. Dispose of antifreeze as per your local laws and regulations. NOTE: Although antifreeze will mainly drain out, the antifreeze has mixed with the water that was possibly trapped in the cylinder water jackets and thus preventing freezing problems. At pre-season preparation, drain the remaining antifreeze from cooling system prior using the boat.
So again (sorry I'm new to this), I'll be running the engine for the exhaust flush but should I follow the shop manual regarding the "antifreeze colant method on the engine head".
Thank you for taking time with newbies.
Have a nice one
Sylvain
