2004 Speedster 200 fluctuating
Asvetz
Any help would be appreciated. I have a 2004 speester 200 with twin 155 hp motors. Not supercharged. Consistently after 30 minutes running the port motor will start fluctuating. If I keep running it will eventually turn off. Took it to the dealer and they said its kicking a MAF code but said its not going into limp engine mode. Has this happened to anyone else?
If you think it is the MAF itself, swap your port and stbd. See if the problem moves or not.
I would do a fuel pressure test. When they get hot the pumps tend to fail and provide less performance if they are failing.
