delta_shop
Hello, I just replaced my 2004 RXP 215HP with a 2011 260 Horsepower engine, I received the engine with the crank and the cam gears already in place, stated in description of eBay that it was a good running engine, I reused my old flywheel (used new flywheel bolts) and reused the back cover, now it will not start, seems like its having a timing issue. Anybody have any ideas of what I did wrong while swapping the engine. When I swapped the engines I was 100% sure they were identical but I didn't not count teeth on the gears. New engine came with the cam position sensor already installed which matched my old plug, crank position sensor I reused from my old engine with the back cover. I checked and the spark plugs are making sparks. Once again I think it is a timing issue because when I'm cranking the engine, it feels like its locking up or/and firing into the exhaust. Please Help!!! I would like to get this onto the water before summer is over.
