Wear ring?.......
Not to sure about the wearing ring but won't say it isn't. The only reason, is once the wearing ring looses it's tolerance, you shouldn't be able to accelerate to top end speed (which I think he quoted as 62).
There are two things I would look at. First, the possibility of sucking in air at the shaft seal, from the engine compartment.
Second, the weight of the person your trying to haul up on a wake board. At 220 pounds, if this person is in-experienced at wake boarding, he may be causing your ski to load up, then loose pressure momentarily in the nozzle. You've got to remember, the torque and performance of a jet pump craft isn't only determined by the engines horsepower. It's determined by the ability to build forward momentum. If you go to high revs and the initial output of the ski cannot obtain momentum to build more force in the low pressure side of the pump, then your not going to get any more nozzle pressure than what you have initially. If this 220 pound person is on the ski, then imagine you riding your bike up hill. It's harder to peddle. Now, have another person sit on the back seat of the bike and try riding up the hill. It's twice as hard to do it. The ski feels the same pain in trying to break the initial friction of floating in the water to getting on plane. Once on plane, friction is a lot less, you probably don't have as much problems. You don't state your weight, so I don't know if your exceeding the weight limit of the craft. It will normally be between 400 to 600 pounds. Now that not just people, but everything else you have on board too.
I'll give you an example to help you understand the theory. While your at WOT, look behind you. Look at the amount of nozzle blast you have. Some of that is caused by the engines horsepower, but a great percentage of it is made in the momentum of the craft. The faster you go, the more water you force into the low pressure (suction grate) of the compressor (pump), so the more pressure you get at the outlet of your nozzle.
Now, nose your ski into a bulkhead somewhere. In a manner safe for you to go to WOT without doing any damage to you or the ski. Now, go to WOT. In a second of so, look behind you. Compare the nozzle blast you see at the stand still and the one you see while moving. Notice the difference?
When the clearance in the wearing ring is lost, you'll normally not be able to generate enough thrust to even get on plane, much less hit 62 mph.
I hope this gives you a little more insight into what may be happening while your wakeboarding.
You also don't mention why the ski is in the shop. I would also like to make clear, that I'm not dismissing the wearing ring posts made by the other members because if it's just starting to wear a little, their statements can also be true. So, here you have alot of input..........something to work with.:cheers:
