I have a 2004 Sea-Doo GTI LE. Found oil leaking into haul. Mechanic found that oil pump that injects oil into carb failed. Ski probably ran on straight gas for a while. He replaced pump and sent back to me. The machine would run for about 15 minutes before losing power and puttering when trying to give it gas. Replaced plugs and would run fine again for 15 minutes. Plugs are fowled up. Was told by mechanic that seals probably bad allowing too much gas, and not worth repairing. Not sure I trust mechanic that the ski is done. Any feed back would be great.
