Recently bought a 2003 Sportster 4tec. I’m a novice seadoo boat owner. That being said, this may be a dumb question. Under the operators seat, there’s a drain hole that is connected to a pipe that runs all the way to the stern and come out near the pump. The outlet is kind of cone shaped and is open on the side facing down to the water. Inside that is a plastic ball. When I stop the boat, water comes from that pipe and flows back inside the hull where then operators feet would be. It’s not a lot of water, but enough to splash with your feet. Is this normal? I’m guessing that the idea is that when the boat stops, that plastic ball is supposed to float into the pipe and keep water from flowing in? After being stopped
For several minutes, I can take off again and the water flows back down the pipe.
