2003 sportster 4-tec, coolant level
seaboy
Good day,
Noticed that antifreeze level in reservoir has gone above max level, whereas it was ok between the max & min last season. Level hasn't dropped after taking it for a 10 minute run. Coolant hoses, eng. head seem fairly hot to touch after the run.
The coolant level was at max level on first run then went above the max level after second run and hasn't dropped since.
Any suggestions/experiences?
Thanks
If the seadoo has over 100 hours on it I would drain it and clean the system and replace it. It is recommended it be done at the 100 hour maintenance.
Karl
