Hey guys, props on the very informative forums you have.
Can't seem to find a solid answer or how to troubleshoot this issue. I bought a 2003 Seadoo Sportster this weekend. It runs and idles great. That being said here are the issues I have found.
1 - Speedometer and fuel gauge aren't working (fuel stuck on full, and speedometer stuck at 0mph). Any ideas? Read it could be F1 fuse, but looks like a pain to replace.
2 - I ran the boat for 2 hours, at the end of the run (about halfway through a full tank of fuel) it started to produce white smoke. I read online this doesn't really mean anything major, I just want to be sure. I checked the oil it still reads full, also checked the coolant, its about 1 inch below the full cold line after letting the boat sit for a day (going to fill it up before the next time). Is there any way to test everything on land before taking it back out? The boat runs and idles perfect, and I have thrust all the way to max.
3 - The hatch in front of the steering wheel no longer holds... where do I buy a replacement gas shock (not sure if that's the right name for it).
4 - Reading through the owners manual I see it has an oil injection system... does this have a separate oil tank, where do I check the level? From what I understand I just need to run 87 octane fuel, there is no oil mix... does the oil injection system need refilled (does it burn the oil as a mix?).
Thanks guys!
Thanks guys!
