2003 RX DI No chirps with lanyard plugged
petesdune
Any ideas for this no power issue. The dealer says it is a cut off relay issue. We are unable to find this relay. Any workarounds?
We get no chirps and the display does not light up. We cannot crank the engine. Pressing the start button several times does not bring up a display.
Have you checked the voltage across the battery terminals? 12.5 volts
Have you checked all the fuses? Pay special attention to the 5amp fuses.
Might check the positive battery cable connected to the starter for corrosion.
If all checks out then I would lean towards the dess post.
Also I have no idea what a cut off relay is or what it does?
The battery was good. It is now in the shop where the other elements have been checked. I believe the cut off relay isolates the battery to prevent it from discharging when the ski is off.
