Hello,
I have an 03 GTX SC stock. I want more speed. Im getting cavitation out of the hole when pulling tubes etc. Im sure the wear ring is shot with the stock plastic pump housing. Im hearing mixed reviews on performance when upgrading to the aluminum pump housing with alot saying you lose power and top speed. I want to do some mods like Riva's stage 1 kit, but sourcing the parts on my own because $800.00 is way too much for that kit, and i already have my OPAS held up with PVC identical to RIVA's OPAS hold up part. I guess I am asking if you have experience with this kind of mod, mainly the aluminum pump housing. Ive read I can use the newer RXP/RXT pumps (159mm) with 159mm wear ring and impeller. However, will that plug and play on my 03 which is currently the plastic 155mm. What are your thoughts and experience on this?
Greatly appreciated,
-Alex
-Alex
