Shop Discount Sea-Doo Parts
2003 GTX DI Project
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
I'm sure this one is gonna have some twists and turns but I'm getting everything ready. Gonna go front to back or back to front as usual getting it in top shape mechanically. Exterior and hull looks good to me. I'm thinking at least a month before I get this one complete. This thing is larger and heavier than the early model
skis. I wonder if it will handle better or worse and what's the strong points?
mikidymac
Moderator
Staff member
Moderator
Messages
12,312
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
The only thing better on that will be rough water and comfort. That is the heaviest hull they ever put the 951 in and the slowest.
mikidymac
Moderator
Staff member
Moderator
Messages
12,312
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
That would be a much better use of it.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
Don't go hatin on the big boy. 50mph is pretty fast... :)
jhjesse
Messages
2,643
Location
georgia
Water Crafts
2000 GTXDI 2002 RXDI
2009 RXTIS
Two 2001 GTXDI's
All depends on what you want to do with the ski. Sometimes the wife and I will take two of the DI skis to the gulf and go exploring along the inter coastal. They sip gas and are great for long rides.
Sometimes we go for long rides on the Tennessee River and they are great for that as well.
Then sometimes I will bring the RXT and rip it to the next marina and get gas then rip it some more.
My DI skis are earlier than 2003 and will get it pretty good when I want to.
Just need to figure out what you want to do.
GGuillot
Messages
932
Location
Alabama
Water Crafts
1997 GTX
1996 GSX
View attachment 43693View attachment 43694
A DI ? Positive, they sip gas, cons they can be expensive to maintain and that newer GTX hull is heavy, I'll bet an early 787 GTX can out run it. Personally you couldn't give me a DI... I hope you didn't buy it to flip...word is out in the 2 stroke community to avoid them at all costs.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
If it is OK with you I will hit you up for info when I put this thing together. I'm gonna send the injectors off for cleaning and get all that stuff prepped for the engine install.
We cut up a little bit on our GTXs but we like to cruise mostly.
jhjesse
Messages
2,643
Location
georgia
Water Crafts
2009 RXTIS
Two 2001 GTXDI's
I am not always on here as I am busy with other things, but I will be more than happy to help you if I can.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
OK, here we go. The engine is ready for assembly and I'm learning some stuff already. LOL This is my first DI. rebuild. I wasn't going to post the details but I figure it may help someone else. I was checking the oil ports for the injection to the cylinders and found a difference. After much diligence in trying to resolve the problem I found the opposite is the true problem
The mag side oil port has resistance. So I checked it with my mitey vac. It bleeds down slowly and I can't really blow through it with my mouth. Port flows great about about 5 psi. The PTO port I can blow through. That one is bad. I'm gonna see if I can get it working or I'll just replace it. Like I said, new to me stuff but these are check valves. I was gonna test with the oil pump as I always do before assembly. Might help someone. I'm sure I'll have more to post along this adventure.
I haven't sent the fuel injectors off yet so the process will be a bit slowed.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
Boy O Boy these first timers sure are interesting. Like a Jigsaw puzzle only with consequences. I think the BEST thing is the parts I have around here. I find the exact parts I need so I don't have many delays at all. I cleaned up the oil port and got the check valve working so we're good there. Engine is coming along.
GTX DI Engine Prep 9-27-19 (1).JPEGGTX DI Engine Prep 9-27-19 (2).JPEGGTX DI Engine Prep 9-27-19 (3).JPEG
jhjesse
Messages
2,643
Location
georgia
Water Crafts
2009 RXTIS
Two 2001 GTXDI's
You attention to detail will pay off later especially with the oil ports.
Great job.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
What a pain in the azz connecting all those lines. I know it always takes 3 times longer for your first one though. I also had to do a lot of checking and fixing what other people broke before I got the ski. :) I
connected a few lines while lowering the engine which was a help but you can't do that with all of them.
Alignment is complete. Engine was about .025" too low. I would sure like to know the factory criteria when they build these skis. I'm beginning to wonder. Throttle bodies installed.... now I can get back to the restoration part. Looks like RED oil in the oil tank. What's up with these people??
mikidymac
Moderator
Staff member
Moderator
Messages
12,312
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
The correct Seadoo XPS full synthetic is red, so that is the correct oil in it.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
Do they have any "off-brand" stuff that is red. I live in Louisiana.... not many people here are gonna pay and use the good stuff.
mikidymac
Moderator
Staff member
Moderator
Messages
12,312
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
Not that I have ever seen. The only one that I have seen red is the XPS full synthetic.
Maybe it's ATF, LOL.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
I'm just covering my bases. Ones less thing I gotta do. :) That's good !!
jhjesse
Messages
2,643
Location
georgia
Water Crafts
2009 RXTIS
Two 2001 GTXDI's
You lake tested yet? :p
Looking good. Did you connect the bottom oil vent line before setting the motor.
I always forget that one and swear a lot.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
On the bottom oil vent.... yes, I connected it before I lowered the engine and still swore at it. LOL Can it be connected with the engine in place? I can't even feel it under there.. I still have to go through the pump end and replace the fuel filters. I'm slow and it's gonna be a busy month for me. LOL I hope you are around over the winter I"m sure I'm gonna need some help with these bad boys. :)
jhjesse
Messages
2,643
Location
georgia
Water Crafts
2009 RXTIS
Two 2001 GTXDI's
I have never found a way to connect with engine in place. Glad it is going good.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
I find the ski with the little rudders on the side don't turn as well as skis that don't have them....like the 1997GTX. I've heard some people remove them. They sure did go through a lot of trouble designing those things. Thoughts??
Users who viewed this discussion (Total:12)
SPONSORED LINKS
Usergroup
