2002 Sea-Doo XP running rough
Messages
27
Likes
0
Water Crafts
1998 seadoo xp limited
2002 seadoo xp limited
#1
I have 2 Sea-Doo XP one 1998 and runs perfect but the 2002 one runs rough and don’t have much acceleration and it won’t go over 40mph and I also notice that it runs out of gas way faster than the other one. I would run both for 2-3 hours the 1998 would still have almost close to full and the 2002 is already at a Quarter of a tank. And also I put new spark plug in it before using it 3 days ago and I just took the spark plugs out and one of the spark plug is completely clean and the other looks dark and oily is that normal?
mikidymac
Moderator
Staff member
Moderator
Messages
9,221
Likes
684
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#4
So then you haven't opened them up, checked the rubber parts, pop-off or leak down?
Matt Braley
Premium Member
Premium Member
Messages
6,778
Likes
136
Location
Niceville, Fl
Water Crafts
I can't keep up with it anymore. I've got some really cool skis!!
#8
Right. There are a lot of crap carb kits out there. You've got to get the real stuff before it's gonna run like it should.
noviceskier
Messages
196
Likes
14
Location
Tennessee, Knoxville
Water Crafts
96 Seadoo HX
96 Kawasaki sts 750
#10
mikidymac
Moderator
Staff member
Moderator
Messages
9,221
Likes
684
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#11
I got the premium venom carb kit
That’s not a genuine Mikuni kit and you need to return it and get the Mikuni ones.
We are only telling you this because we see this all year every year and the problems it causes. Please trust us on this.
mikidymac
Moderator
Staff member
Moderator
Messages
9,221
Likes
684
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#12
JeremyD615
Messages
72
Likes
1
Location
Nashville, TN
Water Crafts
1995 Sea Doo Speedster
1995 Sea Doo XP
1996 Sea Doo XP
#14
A quick look at the diaphragms in the aftermarket kits is all it takes to change your mind about saving a few bucks. They are much stiffer than the factory parts, and the nipples are too long. I can’t remember ever hearing about someone who installed non-OEM carb kits and was happy with the result.
mikidymac
Moderator
Staff member
Moderator
Messages
9,221
Likes
684
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#15
I just looked up the Venom kits on amazon and you can see pretty clear that the diaphragms are the crappy thick molded China ones. Please return them for a refund.
Chester
Premium Member
Premium Member
Messages
1,610
Likes
51
Location
Langley, BC Canada
Water Crafts
98 SXi Pro
#18
Before you do anything, did you check the compression? Did you test the voltage regulator? Are you just assuming it's just the carbs?
Chester
Adsense
Usergroup
