2002 RX leak
mpgazelle
Sat in water 4 days, took on 5+ inches of water at deepest point. Removed water, let it sit in water 12 hours or so. Took on maybe 2". Operated about 15 minutes (moving), rechecked and was almost dry. I'm assuming it self bails when operated ? O rings were bad but could not find correct size and fitted two undersized ones prior to the 12 hour test. (O rings on the 2 plastics plugs at rear.) Plan to get correct O-rings tomorrow. I'm doubting that's the issue considering the quantity of water it took on in only 4 days. If new O-rings do not eliminate the issue where should I look next ? Outdrive seal ? Impeller unit ? Thanks for any suggestions !
Carbon Seal is most likely your issue. And yes, the "Bailers" will pull water out of the hull when at speed.
