Hi all,
just after a bit of help with my seadoo gtx rfi 2002, basically when i have it out of the water on the trailer and run with the hose connected the ski starts and idles fine everytime , revs out to about 6900 rpm and sounds healthy, once i put it in the water sometimes it starts and reaches about 2500rpm and dies down with throttle pressed in full, sometimes it will run good but bogged down at about 5000rpm and then pickup again randomly and continue this pattern if i stop it may not turn back on, and sometimes i cant start it at all ,it may run for a few seconds and then turn off. as soon as its out of the water it starts right back up.
things i have tried by reading other peoples posts
-cleaning the rave valves
-cleaning the fuel tank and using fresh fuel
-fully charged battery
-removed waterbox and checked for blockages
-changed spark plugs
-compression test 155 in both cyclinders
appreciate any help or if you can point me in the right direction as to what i should be checking from these symptoms,
thanks
thanks
