Gonna be an interesting day. Pulled the engine out of the GTX late yesterday. I was considering doing a top end in the ski. For anyone that might come across this situation the exhaust system can be removed without separating the pipe at the joint.
The engine is suppose to be a fairly low hour SBT rebuild (maybe 5 hours run time). I saw some metal jammed in between piston on the Mag cylinder. Found a couple of small chunks of aluminum in the exhaust. I'm kinda excited about what I might find. Cylinder walls don't look that bad from what I can see. I am mulling over what failed that could have locked the engine in such a way. It's a premix so.... we'll see shortly. There is evidence of chicken-shite craftsmenship regarding the install.
I'm not faulting SBT at all. I'll find what happened and as I see with most failures they are operator induced.
