2002 GTX 4 Tec instrument panel dead and long beep when starting
mnasiff
I had water in the engine compartment that filled approx. 1/2 of the compartment. I drained the water and had the hole fixed. I started the machine and the instrument panel, speedometer and tachometer are not working.
when i attach the key, i get a long beep and then 2 normal short beeps. i then start the engine and get one long beep. the machine runs fine but the instument panel, speedomether and tachometer are not working. can you help me fix panel and understand what the long beep means.
thanks
