2002 GTX 4-TEC check engine display
Atwadelle
Currently run for 30 minutes in fresh water and get check engine display. Take lanyard off and replace. Check engine display goes off but comes back in a few minutes. I haven't checked codes yet but read some info that it might be engine temp sensor. Any insights and if engine temp sensor are they hard to replace, if not hard to replace any good sites to get instructions. Thanks
you can get the codes by pressing the set or mode button 5 times. I forget which button but I'm pretty sure the key doesn't have to be on to do this. Should read out the code on the gauge cluster if there is one. If not, it'll just give a short and long beep.
