2001 SeaDoo RXX (Race boat, never raced) Must see + Extras $6000
HCCR5
2001 SeaDoo RXX
Racing Model
(Never Raced)
#85 / 500 Made
Originally Available to ONLY professional Racers
As my son posted this ad, I will not be checking private messages - please email me at jrrhome@new.rr.com or call at #920.494.3991
Sea-doo RXX closed circuit race boat/PWC never raced, used as personal recreational PWC. Produced in 2001 , purchased brand new in the crate in 2003 - #85 of 500 produced, limited production. Sea-doo designed the boat to not need modifications which was done by converting a standard rx. Set up by professional racer right out of crate. Before running boat original factory gas drained, gas tank cleaned, gas filter cleaned, gas lines and carburetors cleaned. Factory recommended injector oil used, throttle and oil injector line adjusted for optimal performance. Hydraulic trim adjusted for optimal performance.
All original factory components except TORX intake grate and larger jets in carburetors after accelerator pumps removed. All original parts are included. The accelerator pumps were replaced by larger jets, 2 point higher secondary jet for front carb or cylinder, this modification avoids front cylinder burn down by supplying needed gas when running at high speed….gas has a tendency to move to back of carbs when moving forward, therefore starving front cylinder, popular problem with 951 motor. This modification also adds horse power, increases acceleration, faster boat and smoother engine…noticeable difference in acceleration, faster out of the hole with smooth constant power…hang on!
Twin stack low restrictive air intakes. Have original air intake plus all others parts.
Factory features:
-Twin/dual exhaust pipes by FACTORY PIPE
-Modified carbs
-Rimaldi reeds
-Skat trak drive shaft, 14 vane stainless steel high out put jet pump
-Three nozzle rings for selected water jet output
-Adjustable sponsons
-Carpet foot and deck padding
-Front water splash deflectors
-UMI aluminum sport/race steering system
-Hydraulic lever actuated trim system
-Hand layer hull for lightness, balance and strength
-Ignition curve modification
-Special comfort seat cover
-Flame arrestors
-160 hp + horse power
-One lanyard- has two
-Specials graphics
-Tachometer only
-Pull choke
-Low restrictive air intake
-Race plate
-VHS tape plus all manuals including RXX supplement manual
Extras;
-R&D (head-not installed)
-TORX high volume intake grate
-Carb jetting
-Twin air stacks
-Duck bill hull water clean outs
-Anchor bag..fill with sand to use as anchor
-Rope
-Factory sea-doo RXX cover
-Extra spark plugs
-Fire extinguisher
-Tool kit- factory supplied
-Extra lanyard
-Fresh Harley-Davidson gel high output battery
Per factory recommendation required maintenance found in the instruction manual, after 20 hours use, rebuild top end - has been done. Actual running hours are a MAXIMUM of 75 hrs use, freshwater only. Stored in garage, heavily fogged every year, water drained and battery removed every year ALSO. Boat has one scratch from a dock, filled and black sticker cover.
This boat is better and faster than standard factory set up. Turn-key boat, needs no maintenance. Always kept in perfect running condition.
Boat is designed for experienced boaters, 75+ mph, throttle has less needed force to depress thumb throttle due to removed accelerator pumps… also saves the thumb from getting sore.
This is an excellently maintained boat, it is very fast and has a lot of thrust out of the hole, and you need to hang on all the time riding due to strong forward thrust, boat handles like it is on rails. This boat is great, but I do not have time to ride it any more, out 3 times in past two years. You will not be disappointed in this boat,
Also, if desired, the trailer is for sale, Chilton 1997 aluminum trailer, winch on post, taller tires from factory, extras include powder coated red, tie down loops, plastic bed sliders, chrome wheels, marker posts, rollers, spare tire on mount. Trailer is light weight for towing uses 1 7/8 ball. Very nice trailer customized to sea-doo PWC , trailer is maintained and ready to go. Price $500.00 on top of purchase of boat.
$6000 OBO
