SeadooMaster
After storing my Sea Doo for winter I got it out of the shed last Saturday, put the battery and fresh plugs in the engine. Fired right up but was running funky... Loss of RPM's and when I hooked the hose up to the Intake the hull began to fill with water. Finally figured out the issue but need help finding what I need to fix it. The Waterbox Rave Valve or otherwise known as the pressure release valve (not located on engine) was leaking water. This may not seem like a big problem but this valve is what brings water to and from the engine and without the correct amount of pressure the hose could melt and potentially seize the engine. Im not sure what to do... There is no parts available and its not worth bringing it to the mechanic because thats money down the drain when I know what the problem is. Let me Know, Thanks.
Evan
Evan
