2001 m2 240 - obd port location, both pumps dead
Messages
44
Likes
0
Location
Long Beach CA
Water Crafts
1989 Seadoo SP -
#1
Hi chaps, trying to get it running, spark on all 6 (only when I remove bk/yellow kill wire) and single beep coming on.. hoping ecm is fine..
But neither pumps are priming despite getting power.. pulling the hi pressure pump today to clean and bench test.. Anything else?
Any idea where the obd port is? Looked everywhere cant find it..
Tx
Messages
204
Likes
11
Location
Fort Pierce, FL
Water Crafts
2001 Challenger 2000
#2
Tx
Tx
Do you hear the lift pump with key on? Someone here said that they had rebuilt that pump. I replaced mine from Rock Auto with generic MARINE low pressure pump.
The VST (injector) pump is a different story. The pump is inside (I know- obvious). If the engine sat for a long time, the gas/oil inside turns to goo. Common problem- the float needle (aluminum) corrodes to the (brass) seat, preventing gas from entering pump housing. There is a drain plug at the bottom of the housing. Fuel pressure should be 35-37 psi.
BTW- make sure the pee hole hose is clear of obstructions. Blockage could cost a melted piston.
Messages
204
Likes
11
Location
Fort Pierce, FL
Water Crafts
#3
As for the OBD port- if you are looking for one like in your car, you won't find it.
It's a Merc only connector. Sorry, can't remember much about it. It does have a cap on it.
Messages
44
Likes
0
Location
Long Beach CA
Water Crafts
1989 Seadoo SP -
#4
thanks tim - yes i know what it looks like, ive got the diagnostic system, i just cant find the darn thing.. Was out of town for a day and will have a look 2moro and report back -
Im pulling the VST tank to see whats going on in there and see if I can get it to come on on the bench
Messages
44
Likes
0
Location
Long Beach CA
Water Crafts
1989 Seadoo SP -
#6
Ok, removed and cleaned vst tank, tapped pump and it started again. Low psi pump was also stuck, opened it up, jumped the transistor a few times and both are running strong!
Never found the port lol - but its firing right up now
Users who viewed this discussion (Total:15)
Adsense
Usergroup
