Shop Discount Sea-Doo Parts
2001 GTX DI Bad Fuel Pump?
Bryce GTX
Messages
6
Likes
0
Water Crafts
2001 GTX DI, 1999 GTX
#1
Just came into this ski and acts like no fuel to injectors. Disconnected the line after the fuel filter, which was highly pressurized, and no fuel comes out of the filter when put on the key or hit start button. Is this a fuel pump issue or is there something else I should check?
It looks like the 2000-2003 GTX DI and RX DI models use the same fuel pump.
Messages
29
Likes
2
Water Crafts
02 Seadoo RXdi
#2
Car you hear the fuel pump running?
Bryce GTX
Messages
6
Likes
0
Water Crafts
#3
Good question... I don't hear anything when connecting the key other than the 2 beeps. I checked the connections and they are perfectly clean. I have not looked for a ground connection issue. If the pump is bad would I still hear something?
mikidymac
Moderator
Staff member
Moderator
Messages
10,220
Likes
843
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#4
If you don’t hear it, it’s probably not pumping.
You should really use an oem pump but there’s only one aftermarket one that works.
There’s a member here that knows the DI skis really well so hopefully he chimes in soon.
Bryce GTX
Messages
6
Likes
0
Water Crafts
#5
Thanks. The fuse is good and went through the connections and they're all good. I'm thinking the pump is dead.
Bryce GTX
Messages
6
Likes
0
Water Crafts
#9
I'm not exactly sure how to confirm power to the pump... I tried checking volts from the pins on the connector going to the pump, but need to research which pins are what.
Messages
29
Likes
2
Water Crafts
02 Seadoo RXdi
#10
Should be the two outer pins I believe. The two middle pins are for the fuel sending unit. I would unplug the fuel pump plug and stick your meter probes on the two outer wires. Then stick your lanyard on the post and see if you get voltage. If you do I would assume a dead pump.
Bryce GTX
Messages
6
Likes
0
Water Crafts
#11
Correct, it was the out 2 pins. Thanks! I checked the outer 2 pins and get 25.2 volts when I connect the lanyard. I pulled the pump and will work on replacing it.
Messages
7,938
Likes
193
Location
Virginia Sea Level
Water Crafts
2001 Sportster LE 951 Carbed
#12
Not sure how you get 25 volts but yeah, those in tank pumps are very common failure items once they get some age on them and you can't use just any pump, yeah it might run but not correctly, it has to be the right one!
jhjesse
Messages
2,539
Likes
46
Location
georgia
Water Crafts
2000 GTXDI 2002 RXDI
2009 RXTIS
Two 2001 GTXDI's
#13
if you don’t hear the pump come on when installing the key most likely the pump is bad. I highly recommend you find a good new/used OEM pump. I don’t recommend any aftermarket pumps.never had any luck with them.
Users who viewed this discussion (Total:6)
SPONSORED LINKS
Usergroup
