Hi guys new to this, and just bought a broken 951 di ... Which may not have been a good idea based on what I have read here ....
Oh well, it's done now ... So I am looking to get it back in the water...
The problems/story so far...
I have taken the engine out ... Took it apart, and 1 piston gone with ring siezed lots of dents in the head... Bent Conrod.. Big end bearing all gone .... And bores scored...
I no nothing about the history... But have sourced the following:
1 replacement crank;
1 recon balance shaft
So the bottom end can go back together...
The current bore had vertex 75 pistons so I think the bore is already 0.75mm over and in pretty bad shape .... So can I rebore without any further issues and put in 1mm or 1.5mm over pistons in ...
Then the top end will be ready to go back together....
Is there anything else I should check/do, as to date I have not found the cause of the meltdown ....
I am currently trying to get it together as cheaply as possible just in case we it goes back together it does not work .
Any advice or am I throwing good money after bad?
Thanks in advance
Thanks in advance
