2001 GTI speedometer fix
Messages
54
Likes
6
Water Crafts
2001 gti
1995 SP
1989 SP
#1
Hey guys, it's still winter here in the Midwest, and my 2001 gti is still in storage but I want to fix the speedometer soon. What are the common problems that cause a seadoo speedometer to not work? It has the paddle wheel, and the paddle wheel spins freely. The speedometer is also an analog style, what should I look for first when diagnosing the problem?
Messages
11
Likes
0
Location
Westchester NY.
Water Crafts
current
2001 GTX DI
2007 GTX LTD
1998 Speedster
old
98 XP LTD
98 Kaw 800
#6
I installed the CanDoo Pro GPS speedometer module and it works great for me.
mikidymac
Moderator
Staff member
Moderator
Messages
5,884
Likes
123
Location
California
Water Crafts
2003 GTI
1996 XP
2001 XP
1996 HX
2x 1997 GSX
#8
I would think the gauge reads resistance and grounding it might go to full speed but I’m not sure so you could risk frying it too.
Messages
11
Likes
0
Location
Westchester NY.
Water Crafts
current
2001 GTX DI
2007 GTX LTD
1998 Speedster
old
98 XP LTD
98 Kaw 800
#9
from the manual
To check if the speed sensor is operational, disconnect
the speed sensor connector housing
from inside bilge.
Using an appropriate terminal remover (Snap-on
TT600-4), remove the PURPLE/YELLOW and
BLACK/ORANGE wires from the tab housing of
the speed sensor.
Reconnect the PURPLE/YELLOW and BLACK/
ORANGE wires in the receptacle housing.
Connect the positive probe of a multimeter to
speed sensor PURPLE/YELLOW wire and the
negative probe to speed sensor BLACK/ORANGE
wire.
With the safety lanyard removed, depress the start/
stop button to activate the MPEM timer.
Slowly rotate the paddle wheel. Every 1/8 turn, the
observed voltage should fluctuate between 5.5
and 8.5 Vdc.
Users who viewed this discussion (Total:2)
Adsense
Usergroup
