Shop Discount Sea-Doo Parts
2001 gti driveshaft removal
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
I have gotten the rubber boot off where the driveshaft connects to the PTO and I know some people say to remove the "c clip" when removing these driveshafts but I cannot find it anywhere. What am I missing? My driveshaft won't budge
snikwad003
Messages
1,498
Location
NC
Water Crafts
'97 Challenger 1800
‘98 SPX
‘97 XP
2 '04 honda r12x salty and corroded
The c clip could be a rubber oring or you're not pulling the stainless hat back far enough, is the pump still in?
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
I can't find the rubber o-ring anywhere, where can I find it? And how would I remove it
snikwad003
Messages
1,498
Location
NC
Water Crafts
'97 Challenger 1800
‘98 SPX
‘97 XP
You slide the thing that looks like a metal top hat towards the impeller and it will be around or hanging on to the driveshaft
snikwad003
Messages
1,498
Location
NC
Water Crafts
'97 Challenger 1800
‘98 SPX
‘97 XP
Is the pump still in?
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
Yes the pump is still in but the motor mounts are out and I know I will get murdered for this but I am trying to slide the motor out with the pump still on, I'm trying to rebuild my bottom end on the fly. So I should slide the motor forward and the shaft should expose a c clip?
mikidymac
Moderator
Staff member
Moderator
Messages
12,317
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
No need to go to all the trouble I’d you aren’t removing the pump. Just pull the engine forward farther. The only thing holding the engine to the driveshaft is the rubber boot on the PTO flywheel.
That being said you should have the pump out so you can align the engine when it goes back in. If you don’t align the engine you risk damaging the driveshaft seal and splines.
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
See but I removed that rubber boot, I pulled as hard as I could and it's not moving.
Is there a chance that it's stuck in there?
mikidymac
Moderator
Staff member
Moderator
Messages
12,317
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
It could be stuck. Give it a pump of grease.
mikidymac
Moderator
Staff member
Moderator
Messages
12,317
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
It can’t hurt and might lube it so it comes out easier. Nothing else is holding it in there but friction.
Honestly you’re better off pulling the driveshaft and pump correctly.
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
As always, you're right mikidymac, I'll have to just do it, the pump takes a few minutes to pull if it's not stuck anyway, it's just hard to be in the garage with this 80 degree weather
snikwad003
Messages
1,498
Location
NC
Water Crafts
'97 Challenger 1800
‘98 SPX
‘97 XP
There is a guy on YouTube that hydroforms steel with a grease gun, scrapes the grease out, puts it back in the gun and does it again
mikidymac
Moderator
Staff member
Moderator
Messages
12,317
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
You need to get the stainless hat off the driveshaft seal before you pull the pump or you will have nothing to push against to slide it back far enough to remove the c-clip or o-ring that retains it.
iroc34
Messages
10
Location
Illinois
Water Crafts
2001 GTS , 1987 Kawasaki 650sx, 92 Sunbird Corair 185 IO.
Pulled my engine last night the same way (01 GTS) After the engine mount bolts were removed, I used a big pry bar between the rubber mount and engine mount, and just gave it an easy push, popped the shaft right out .
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
I would do that but my shaft has already slid out of the end of the pump,band has some play. Not like it can slide all of the way out, but it moves around everywhere. It's just a mess and I've been working 12 hour days since I've posted this so I haven't been able to work on it at all. I just want this shaft out so I can start rebuilding this motor and get back out
iroc34
Messages
10
Location
Illinois
Water Crafts
Then your gonna have to remove the pump to get it out of the fly wheel/ harmonic balancer end.
Cheflen
Messages
291
Water Crafts
2001 gti
1995 SP
1989 SP
I'm hoping that'll be my last resort, I'll try what I can to force the shaft out before I take the pump off
Digdog
Messages
264
Location
Saskatoon
Water Crafts
Seadoo RXT-X 260
Can you just remove the shaft adapter plate ? 6 Allen head bolts and the shaft/plate should be separate from the engine.
mikidymac
Moderator
Staff member
Moderator
Messages
12,317
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
A 01’ GTI has the 720 engine. Only the 951 uses the bolt on spline coupler.
SPONSORED LINKS
Latest posts
Usergroup
