Uncle_Tone
Does anyone have a video on this DIY?? I want to rebuild the air compressor but want to know at least some kind of direction before I start. Thanks
Ok thanks, that’s kinda what I was thinking. With the fuel I was thinking just taking the online filter out and placing the “t” there. I don’t see any problem with that. Correct psi with key on should be about 27psi, cranking about 107psi if I am correct. The air pressure remains at 80psi no matter the amount of throttle being applied, also if I am correct.You can test the air pressure with a compression gauge. Attach your gauge at the top of the hose that comes out of the air compressor. You will need to mc gyver a hose to make the connection. Leave the plugs in, caps off, and turn the motor over for a couple seconds, it should scoot up to 80 psi or so.
Testing the fuel pressure is a whole different story.
I have yet to find a video on here to do both these tests.
So thats the thing. I was charged for an OEM fuel pump but how can I tell is its aftermarket??Was a genuine seadoo pump installed? Most have pressure issues with aftermarket pumps.
Thats what I thought. Well I'm still within the 12 months. I just want to make sure it is the pump and not a regulator or a check valve or something silly like that. Maybe even a clogged filter at the bottom of the tank.You can't unless you pull it and even if it's OEM most places only have a 12 month warranty on their work.
So it looks like we are singling our the pump here, correct??I have Yet to have a plugged/blogged tank bottom check valve as a cause for low or not holding fuel pressure. (I'd be so lucky). I believe that the OEM pump (that has a check valve built into it), is of course contracted to an outside source,
BRP.Google
Good question, I think if it were me I would go ahead and just do it anyways since the engine would be out of the hull.Back on the topic of air compressors, is a rebuild recommended as proactive maintenance or only if pressure is low? I am picking up my GTX DI project ski this weekend and will be rebuilding the engine. Should I go ahead and hit the air compressor while I am in there or are they pretty reliable? The engine is coming out so it should be pretty easy.
Hahahaha, typo!!! Of course I cleaned it out!!!!Why would you not clean the dirt and sand out of the pump??
