I have a no start no beep situation on a 2000XP. I originally thought it was the DESS post, as it failed the blk/ blk/ ylw wire continuity test. I replaced with new with no change.
My MPEM is not getting power, I have a good battery providing 12.5v at solenoid & no blown fuses. I tested (multimeter) every wire in all 3 AMP plug connectors and nothing is hot. I am 100% sure I had a good ground. My shop manual provides a good wiring schematic but I cannot determine where the MPEM gets its power from.
Does any one have any ideas? I am prepared for the worst (bad MPEM) but if I cannot determine that MPEM is getting power I cannot condemn it. I know you cannot test the module...but there must be a way to determine which wire provides the module with power.
Thanks
-Dan
Thanks
-Dan
