2000 speedster pump oil change question?
scooter240
I am looking to change the pump and stator oil...Does anyone know if there is a oring or flat washer on the drain and vent??if so do u have part #?
ty
ty
Yes, there is a fiber washer/gasket under the screw head.
Any Merc dealer has them.
on merc I/O i have had, ive used the rubber coated stainless vs the fiber washer...just wondering wich one u have used for the seadoo?ty
As I said-
Screw with fiber washer. Don’t scratch the surface of the casting. You can create a leak.
anyone have manual to show how may ounces the pump and stator hold of the high performance gear oil? i drained the pump and got approx 16 ounces but i thought i read it should be 27 ounces(may of been for different year/model)? i am waiting for drain plug gaskets to get here to see how much it takes but hoping someone had a manual or has changed theirs and has answer???? has the merc 240 hp 2 stroke
This jet-drive service document says:
stator: 19oz. Mercury High Perf. Gear Oil
gearbox: 27oz. Mercury High Perf. Gear Oil
Cheers!
  • Jet_drive_annual_service.pdf
Cheers!
