Hey gang,
Has anyone discovered a cost effective workaround for the dreaded TPS failure? Troubleshooting rough idle. Mine is testing all over the map, wild swings in resistance, not a smooth sweep,and the resistance changes every time the throttle returns to idle. Will set it to spec, then advance to full to test WOT. return to idle, and voltage reading is off spec again. Don't really want to stick 500 bucks into a sensor, but don't see a whole lot of options. I know there was talk about a "engineered replacement at one time, but I think the discussion died on the vine.
