This ski has been running great since I bought it late last year. Just started acting up. When I give it WOT it runs up to around 4000 RPM and just sits there for 5 to 15 seconds, then it kicks in and runs great. Around 50 mph. Acts worse under more load, like 2 or 3 people on ski or pulling kids on tube. Compression check showed 145 front and 150 rear. Battery voltage was 13.17 before starting and 13.50 on trailer at 3500 rpm. From what I read that shouldn't indicate rectifier problem. Not sure if rectifier is upgraded or stock. Any ideas what else to check that could be causing hesitation? Or could this still be a rectifier issue causing limp mode then overcomes issue?
