Bought 2 PWC for cheap, not running as they had been sitting for 12 years. I have since rebuilt the carbs, ran new fuel lines, changed spark plugs, re-covered seats, and cleaned em. That's it. They both run pretty damn good, wish I had seen the carb rebuild sticky here before hand but things turned out well.
One is a 94' Seedoo XP, and the other is a 94 Kawasaki SS 750.
- What else should I check/replace before the maiden voyage?
- Is there engine/gear oil to change?
- Should I change the jet pump oil on em before testing in the lake for a bit?
- What should I check to ensure I won't be taking on water?
- How does the bilge system work on these?
- The seedoo has riveted footpads that are coming up, will those loose rivets cause me to take on too much water to test em this weekend?
- The trailer has stationary mount points for the PWC. The kawasaki is properly mounted with a rubber L bracket thing that a pin slides through into the front anchor hole. The seedoo however has a mounting point not directly on the front nose, but rather a loop underneath the bow. How do I properly mount this to the stationary pole on the trailer? is there some sort of other rubber bracket for it that I don't know about?
