1999 gxi troubles
Mike77802
1999 gtx troubles
started out running fine, then sounded like was sucking air or something and wouldnt run over 45mph, 12v light came on heading back to trailer and right before got to trailer the low oil light came on, had little over 1/4 full of oil. Would start everytime until the next morning was gonna check it out and it wont even turn over, beeps when u connect key and just clicks when u hit the start button, not the battery, the local shop put on a new starter last yr.
Your rectifier/regulator unit probably went bad. It will do strange things while running, and can drain the battery while sitting.
