This ski would crank up and run great in the water for about 10 minutes, then die. Try to restart and it would crank very slowly and not fire up. Took it to local Seadoo dealer who said one of the cylinders was scuffed, and after running for a while, piston was seizing up in this cylinder; he wanted to put in a new engine or rebuild the old one for about $3K!!! I bought an oversize piston kit, had the head bored out to match oversize kit, reassembled the engine. The engine starts up fine, but theres an internal rattling noise fron motor, like its not lubricating properly. I bled out oil pump line, it appears to be working OK. Should I add 2-cycle oil to gas to break in new pistons, or will it clog up the injectors? What could the rattling noise be from?
