1999 GTX LTD Bogs Down
09davidk
Hello, i have a 1999 Seadoo GTX LTD 951. I recently just rebuilt the engine and carbs. The only diaphragm that wasn't replaced was the accelerator pump diaphragm. The engine fires right up and idles good. it is a little hesitant when you dump the throttle to it then picks right up, but when i put it in the water i start it up and it gets right up out of the water and runs good for about 20 seconds then starts to bog down. If i shut it down and let it sit for a minute or two, it will fire right up and rap up to about 5000 rpm then bog down again. Each time i do this it gains a few more RPM. I have checked all the fuel filters and it has new NGK plugs. I added a little bit of oil to the fuel as the manual said to do for the first tank while breaking it in. I thought maybe that was the problem but im highly doubting it. Any suggestions would be great. Thanks, Kyle!
