mgrant
I'm new to this forum so let me start out by saying hi to all. I just bought a 98 sportster 1800 in great shape for its age. it just has one problem and i can't figure out how to go about fixing it. i am by no means mechanically inclined and need help! it idles strong, runs low rpms strong, and runs high rpms strong. middle rpm causes the left engine to bog down and stall out if the throttle is not immediately opened up or let off of. the problem starts around 3500 rpms and continues to around 4000. when i increase throttle slowly, at 3500 rpms the motor will automatically back down to to around 2500 rpms and soon stall if no further throttle action is taken. the right motor runs great all the way around. i have replaced all spark plugs, put a can of sea foam into the remainder of the gas that came with the boat, and run the boat nearly empty of fuel. to the best of my knowledge the boat was not run often last season, and was not winterized last winter, so i am assuming from other things i have read that this is a gummed up carb problem, but i really have no clue. any troubleshooting help or help in general would be greatly appreciated. thanks!
