1998 Seadoo XP blowing 15 AMP fuses. Running perfect the last two years. Riding today... hit a wake got sideways... I'm half on half off the ski... reach up and yank the lanyard to shut it off... never flipped over. Get back on ski. Nothing. No beep... no power to gauges... Tow it back in.
Replace 15AMP fuse in main fuse box (the one with 3 main fuses and two spares) next to MPEM. It's blown. Replace the 15 AMP fuse and get the good double chirp. Close everything back up and try to start... nothing. Disconnect battery. Check 15 AMP fuse in MPEM... it is fine.
Check the 15AMP fuse in the "electrical box" at the front/rightside nose of the ski and it is blown. Replaced it. Reconnect the negative terminal on the battery (it arcs...) replace 15AMP in MPEM. Double chirps... Starts fine... Shut it off. Remove lanyard from post... wait 10 secs and put lanyard back on...nothing.
Check 15AMP fuse next to MPEM... it's fine. Check other electrical 15AMP fuse on front righ...blown.
Do I have a short somewhere? I can get it to start once and run (so it isn't MPEM otherwise it wouldn't even validate my lanyard) ... but after shutting off... and trying again get no beeps. Either blows the 15AMP in the MPEM or the 15 AMP in the front electrical box. I'm out of fuses. Any ideas?
Thanks.
I have pictures if anyone is interested... sorry I don't have all the proper terminology.
JOE
Thanks.
JOE
